2001 Mitsubishi Galant Water temperature gauge is high
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAKS
Hi everyone,
I read several topics here about the same problem that I have with Galant's overheating.
But mine is a little different, when I am driving water gauge is in normal position, but when I stop, it goes up.
Here's what I did: replaced the radiator because the mechanic said it was cracked, which I am still not sure about. The new radiator didn't solve the problem, now I changed the thermostat and still no result. What should I do? Please help!
About the fans I am not sure, I think they dont work properly, because when I stop the car and while engine is running, fans are not working at all, but when I turn on the AC they start spinning!
Please help !
Thanks,
Max
Jul 19, 2008 at 2:45 PM
  • 31,937 POSTS
Hi there,
one fan should come on when the temp is high, the A/C will also turn on the fans when in operation, i would ask the mechanic to inspect the thermo fan sensor first, this is not the temp sender as don't get them confused.
mark (mhpautos)
Jul 19, 2008 at 7:40 PM
MPAE100
hey Maks,
I am actually having the exact same problem that you did more than 2 years ago. I went to an autoshop and they said that I had to replace the water pump and timing belt. Did you discover what the exact problem and solution was??
Thanks,
Mike Pae
Mar 22, 2011 at 4:02 PM
