2001 Mitsubishi Galant vibration after the timing belt was
2001 MITSUBISHI GALANT
SLMAX
Noises problem
2001 Mitsubishi Galant 4 cyl Wheel Drive Type unknown Automatic 112000 miles
I had the timing belt and the balance shaft belts changed last week along with the tensioners and idler. I also had all the drive belts replaced. The next morning, when I started the car, there was a very loud vibrating kind of a noise from the engine. When I drove the car, it was misfiriing , then we discovered there was an oil leak, so the valve cover gasket and the plugs were then replaced. The following morning, when I started the car, the noise was still there, and it has been there every since. The RPM is stable, doesn't move up and down, however at lower RPM the vibration seems greater. None of this existed before replacing the timing belts, could there be problem with the work done?
Mar 2, 2008 at 10:28 AM
MASTERTECHTIM
  • 4,750 POSTS
absolutely. why was the timing belt replaced?
Mar 2, 2008 at 10:29 AM
BMRFIXIT
  • 19,053 POSTS
recheck balance shaft belt and marks
https://images.2carpros.com/forum/automotive_pictures/99387_mitsu_1.jpg
Mar 2, 2008 at 10:36 AM
SLMAX
There was no timing belt issue or performance problems prior to replacing the timing belt, it was just done for maintenance reasons. Thanks :)
Mar 3, 2008 at 7:40 AM
MASTERTECHTIM
  • 4,750 POSTS
dont say you heard it from me but you have to put up a stink. dont be rude but let the shop know that you are not happy and want it fixed. you get more bees with honey. if they are any kind of a decent shop they will repair it. keep us posted.
Mar 3, 2008 at 8:15 AM
