2001 Mitsubishi Galant Tapping sound from the Engine after
125,000 MILES • 4 CYL • 4WD • AUTOMATIC
FRIENDKSUBEDI
I recently got timing belt, water pump and Balance belt changed in my 2001 Mitsubishi Galant 2.4 L ES at 125000 by a local mechanic. Then I noticed a tapping/ knocking sound after the repalcement of those items. I doubted that the timing belt was not properly installed. So I went back to the mechanic and talked to him. He said that the tapping/ knowcking sound ( tiktiktik...) is the sound of the lifter and it goes off after few weeks. But it did not go. He said that go to Mitsubishi dealer and ask them why your car is making such sound. Then come to us and let us know the problem. I am a exchange visitor teacher and I don't know many people here. Would you please help me what should I do? Do you think that the tapping sound is comming from the lifter? Do you think that they have installed the timing belt properly?
Jun 8, 2008 at 6:36 AM
KHLOW2008
  • 41,812 POSTS
Hi friendksubedi,
The lifters used in this engine are hydraulics and tend to produce some tapping noise, esp when engine is idling.
The noise would go off and come back later. If you want to solve the problem, you have to have the lifters serviced or replaced if it does not respond to cleaning.
You can use the car without any problem.
Jun 9, 2008 at 2:36 AM
