2001 Mitsubishi Galant my car shakes when put on drive
2001 MITSUBISHI GALANT
JOSH_URBANO
2001 Mitsubishi Galant 4 cyl Wheel Drive Type unknown Automatic 80546 miles
once i get into my car and turn it on it shakes a little bit so i guess its normal... but then when i shift it down to DRIVE the floor and the wheel shakes like vibrates pretty strong... is tihs a serious problem?
thank you
Jan 27, 2008 at 4:42 PM
BART FURP
Have your timing belt condition checked IMMEDIATELY. My Galant was doing the same thing and I wasted $hundreds replacing motor mounts with no improvement. What happens is, the timing belt gets old and starts losing teeth, allowing the harmonic balancer to go gradually more and more out of correct position, which causes the car to shake like an off-balance washing machine. Make sure that the mechanics put your balancer back in correct position when they replace your timing belt (unlike the idiots who did mine)...
Jan 20, 2011 at 1:03 PM
