Fuel filter location
217,690 MILES • 4 CYL • 2WD • AUTOMATIC
RHOSHELLA
Where is my fuel filter located on my ES model?
Aug 16, 2010 at 7:32 AM
DOCFIXIT
  • 18,828 POSTS
THe fuel filter for this car is in the fuel tank with the fuel pump here is a guide and diagrams below to show you how to change it out. The pump has a trap door which is nice so you don't need to drop the tank
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers
Aug 16, 2010 at 8:13 AM
FIRECHIC_86
Where is the fuel filter?
Sep 29, 2018 at 10:58 AM (Merged)
  • 31,937 POSTS
There is only a in tank filter in the pump, normally you do a fuel flow & pressure test and if it is below spec's you replace the pump.
Mark (mhpautos)
2CP-ARCHIVES
  • 4,540 POSTS
How do I replace the fuel filter on this model and where is it located?
KHLOW2008
  • 41,812 POSTS
If no fuel filter is found at the firewall, it would be in-tank, together with the fuel pump access from under the rear seat.
EDWINA11
How do I remove the fuel filter?
Sep 29, 2018 at 10:59 AM (Merged)
HERC20002003
  • 11 POSTS
Under the back seat remove the cover then remove the fuel pump. The strainer is on the bottom.
SSOUTHBELL
change fuel filter on 95 mitsubishi galant s
DOCFIXIT
  • 18,828 POSTS
Mounted on bulk head to right of brake booster. kinda tricky to get off bolt on banjo fitting VERY tight and comes off best with air wrench. line on bottom will need metric line wrench
DAVID JEROME
  • 5 POSTS
When is it necessary to change a fuel filter for a 1998 galant that has gone 115000 mls and what are the signs that a filter needs changing?
BLUELIGHTNIN6
  • 16,542 POSTS
There is no scheduled maintenance interval for your fuel filter. Only replace it if the engine is struggling for fuel. A bad / clogged fuel filter will cause poor fuel mileage and may cause a poor idle condition due to the engine starving of fuel, but it is very rare for a faulty fuel filter to prevent the engine from starting.
