2001 Mitsubishi Galant changing the bulb in the head light
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAREL50
can not figure out how to get the bulb out of the headlight to replace
Nov 8, 2008 at 2:38 PM
IMPALASS
  • 3,112 POSTS
Hello
https://images.2carpros.com/forum/automotive_pictures/248015_1_22.gif
Disconnect the connector. Remove the socket cover. CAUTION: Do not touch the surface of the bulb with hands or dirty gloves as the bulb may pop after a short time. If the surface does become dirty, clean it with alcohol or thinner, and let it dry thoroughly before Installing.
https://images.2carpros.com/forum/automotive_pictures/248015_2_32.gif
Unhook the spring securing the bulb, and then remove the bulb. CAUTION: Do not touch the surface of the bulb with hands or dirty gloves as the bulb may pop after a short time. If the surface does become dirty, clean it with alcohol or thinner, and let it dry thoroughly before Installing. Install the spring and sealing cover securely after the bulb replacement, or the lens will be out of focus, or water will get inside the light unit.
Nov 9, 2008 at 3:23 PM
