2000 Mitsubishi Galant Timingbelt Replacement
130,000 MILES • 4 CYL • FWD • AUTOMATIC
LEO MILNER
The car was running fine then it just died while driving along at 45 mph.the car was towed home, I proceeded to disassemble the outer belts,(alt. ac. &ps.)so I could pull the timing belt cover off. Thats where my lack of knowledge comes in, Ibelieve I got all the bolts out, yet I cant get the timing cover to come off. Is there a hidden bolt somewhere or some special procedure I have overlooked? Please help if you can....Thank you.
Jun 7, 2008 at 6:08 AM
KHLOW2008
  • 41,812 POSTS
Hi Leo Milner,
If all the bolts are off, the cover should be loose. Check which point is stuck and you might have missed out on a bolt. If you have not taken out the crankshaft pulley, behind it there are 2 bolts.
Jun 7, 2008 at 6:39 AM
JPALOMINO28
  • 6 POSTS
if replacing the timing belt, you are replacing the gasket, so buy the gasket, and count the bolts you took off.
Jun 18, 2008 at 9:56 AM
