2000 Mitsubishi Galant studs broke
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
BALLER1717
wheel is off and studs 3 out 5 are broke how can i repair. How can i get the studs out ? I cannot get it to the shop without towing and i don't want to tow?
Thank you .
Oct 12, 2009 at 9:07 AM
  • 75,988 POSTS
You need to remove the hub -either you replace the hub or have the broken studs pressed out-
Oct 12, 2009 at 10:58 AM
