2000 Mitsubishi Galant Replaced Engine
2000 MITSUBISHI GALANT
STUMPFY09
  • 6 POSTS
Engine Performance problem
2000 Mitsubishi Galant 4 cyl Two Wheel Drive Automatic
I just got finished replacing the engine in a 2000 mitsubishi galant and it doesn't want to idle. Timing is right and runs fine when you put the gas to it. Is there a "learning" period on mitsubishi's like there is on older gm's and mercury? Anything would help thanks.
Jul 28, 2009 at 11:05 PM
  • 31,937 POSTS
Hi there,
You need an OBD-11dlc scan tool to access the correct sections in the ECU to do this adjustment, do you have access to this equipment?
mark (mhpautos)
Jul 28, 2009 at 11:13 PM
STUMPFY09
  • 6 POSTS
I think i can get a hold of one. I don't have much experience with them though. Can i take it on the interstate? Will the car go through its idle learn there or is a scanner the only way to get it right. Thanks for your help and time. Phil
Jul 29, 2009 at 7:56 AM
  • 31,937 POSTS
Hi there,
From what i read it won't do a self re learn, the ECU is holding the idle memory of the previous engine and it is getting conflicting signals from the sensors on the new engine, a dealer should be able to do this easily, and i feel that above idle it will be fine.
Mark (mhpautos)
Jul 29, 2009 at 9:19 AM
STUMPFY09
  • 6 POSTS
yeah it runs like a top above idle, it just doesn't want to idle. I will take it to a dealer to get it reset. thanks for your help
Jul 30, 2009 at 8:28 AM
  • 31,937 POSTS
Hi there,
Good move, drop us a line if you have any more problems, good luck.
Mark (mhpautos)
Jul 30, 2009 at 10:28 AM
