2000 Mitsubishi Galant Repair Code??
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
WMGROSS
Took car to Midas because of undercarriage noise. They fixed the noise problem (by welding shut a hole in a pipe) but then I couldn't start the car although I've had the car for about four years and never had any sort of starting or battery (or radio) problem. Midas told me the problem was a corroded terminal on battery. Took the car to Sears but the radio wouldn't work. Sears replaced the negative cable and the battery but the radio still wouldn't work. Service man told us the radio was asking for a code and I was told to give the VIN number to Mitsubishi and they would give me the code. Is this possible? If it is, who do I get the code from and what do I do to get the radio working?
Oct 15, 2008 at 2:28 PM
RACEFAN966
  • 5,029 POSTS
Yes this is it is known as a theft lock radio. When the battery is disconnected it locks the radio untill you give it a code. This can only be done by the dealer that I know of.
Oct 15, 2008 at 2:34 PM
