I have a 2000 Mitsubishi Galant with 75k miiles and the radiator cap is spraying coolant from the radiator. The car is also overheating at low speed but when cruising at higher speed the water temp drops. Would that be caused by the thermostat being stuck closed or the water pump failing?
Jul 22, 2008 at 4:18 AM
