I found that around the radiator there is some greem moisture around it and needs to need to know if this is serious or something minor.
Dec 11, 2008 at 9:36 AM
✓Experienced Mechanic
Hi there,
This will be coolant leaking, you will need to get a cooling system pressure test done to determine the extent of this problem, it may just be a hose that needs re tightening, get this done first.
