2000 Mitsubishi Galant Manifold
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUEZIQ
Hi could you please advise, i have just changed my spark plugs but did not do the gasket as there was nothing wrong with it, i am now having problems with a very strong fuel smell as well as a missing/stalling in the engine when trying to drive.
i took the gasket off and used a universal gasket solution to stick it down but this has not helped the car is really not feeling right it has a vibration in the steering . PLEASE HELP.....
Dec 15, 2009 at 9:44 AM
  • 31,937 POSTS
Hi there,
I would be fitting a new gasket as you may have a vacuum leak, i would also just be checking all the connections & vacuum hoses that you removed to do the plugs, start here.
mark, (mhpautos)
Dec 15, 2009 at 6:42 PM
