2000 Mitsubishi Galant 2000 galant only stays on if gas is
2000 MITSUBISHI GALANT
182,410 MILES • 4 CYL • FWD • AUTOMATIC
STEVE SMITH 1421 6TD
  • 8 POSTS
The car will turn over but cut off immediately if the gas pedal is not pressed.I don't now where the fuel filter is located at or if it's serviceable.
Sep 24, 2009 at 3:12 PM
Hi there Steve Smith 1421 6TD and TY for the donation this is what keeps our website going
Check and test the idle air control motor, EGR and PCV valves, throttle position and manifold absolute pressure sensor and get back with some testing results so we continue to assist.
Sep 24, 2009 at 4:06 PM
  • 8 POSTS
what would be the proper way to check all of that listed. i tried getting a diagnostic ran on the car but it will not work unless the car is able to run by itself
Sep 27, 2009 at 6:04 AM
The fuel filter could be on the fuel line if not its in the fuel tank.
Replace the idle air control motor/valve its job is to maintain the idle speed at all times without using the gas pedal
Sep 27, 2009 at 6:23 AM
  • 8 POSTS
don't know if this will help any but when i actually get the car on the highway and i am driving the brakes are very stiff.
Sep 27, 2009 at 12:39 PM
Rescan the computer with or without a check engine light. if there's any code/s comeback with it-whether it can idle or not-
You need to check and test what I've suggested earlier and report all your testing results so I can determine what's really going on here.
Sep 27, 2009 at 5:03 PM
  • 8 POSTS
i figure out what the problem was the intake manifold snapped where it connects to the carburetor, new problem though, i replaced the intake manifold but it snapped again i need to figure out what keeps causing the intake manifold to snap
Dec 3, 2009 at 7:44 AM
