2000 Mitsubishi Galant
131,000 MILES • 6 CYL • FWD • AUTOMATIC
MLAVIGNE
Transmission does not shift into drive or reverse. There was no noise from the gears before it went out. It started with the cruise control going out. Then it started slipping in second gear. Then it stopped shifiting completely. What do you think needs to be done and how much will it cost?
Oct 19, 2008 at 3:25 PM
TECHNOPRO
  • 45 POSTS
If your transmission started slipping before then you might be looking at a transmission rebuilt. About the cost, I'm not sure but it would be wise to shop around a little bit and ask some feedback from your mates and always make sure you get warranty on the job done.
Oct 23, 2008 at 8:33 PM
