1999 Mitsubishi Galant SRS
120,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVID4243
The SRS light keeps popping up and I don't own a manual for this vehicle. I notice that the car engine seems to be shaking whenever I'm stationary like at a light or in a parking spot. The other day I turned the key in the ignition and at first the car didn't turn over. Then when I tried the second time it did.
What does the SRS light mean??
Thanks.
Feb 1, 2009 at 4:30 AM
VDOG72
SRS means Supplemental Restraint System. It is the system that control your airbags.
The light coming on could be plenty of different reasons:
- Battery Low
- Blown Fuse
- Faulty Airbags
- Unplugged or faulty sensor
Best way to check would be with a scan tool.
As far as the car not turning over, the SRS has nothing to do with that.
I know there is a recall for 99 - 01 Galants for a faulty battery cable, might be worth it to check it out.
Let me know how it works out for you, best of luck!
- V
Feb 3, 2009 at 2:02 AM
