1999 Mitsubishi Galant speedometer light burned
86,000 MILES • 4 CYL • FWD • AUTOMATIC
AMERCANTE
the lights of the speedometer clock seems to be burned because I can not see the clocks very clear.How can I replace it,how can I reach the burned bulbs.Can the problem be the fuse?.Thanks so much.
Jul 12, 2008 at 2:14 AM
KHLOW2008
  • 41,812 POSTS
Hi amercante,
If it is the fuse, other dash bulbs would not be working.
Should be the bulb and you need to remove the meter assy to replace it.
Jul 12, 2008 at 6:34 AM
