1999 Mitsubishi Galant safety restraint system
1999 MITSUBISHI GALANT
EVILLYNN
1999 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic 172k miles
recently my SRS light came on and i would like to know once i diagnose and correct the problem if i have the ability to reset the SRS ECM myself or if this is a dealer repair only?
Feb 26, 2010 at 7:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you need an SRS enable diagnostic scanner to retrieve the SRS trouble code(s) stored and then delete the codes after repairs are made. if you don't have the scanner than a repair shop will have to do it for you.
Feb 26, 2010 at 8:51 AM
