1999 Mitsubishi Galant head bolts
1999 MITSUBISHI GALANT
156,000 MILES • 4 CYL • FWD • AUTOMATIC
SXPCK66
  • 5 POSTS
what is the torque for the head bolts and the order
Oct 28, 2008 at 1:25 PM
DLOBI
  • 125 POSTS
Found this online for you..
Torque Sequence
Front | 8 6 1 3 9 |
Of | 10 4 2 5 7 |
Engine ------------------------
Step 1 - Torque to 58 ft/lbs
Steps 2 - Loosen all bolts
Steps 3 - Torque to 15 ft/lbs
Steps 4 - Turn 90 degrees
Steps 5 - Turn 90 degrees
Recheck final torque in sequence
Caution:
Engine uses torque to yield head bolts (TTY)
that permanently stretch during initial installation.
New head bolts must be used when cylinder head
is replaced or re installed to obtain proper
torque specification
Oct 28, 2008 at 1:49 PM
SXPCK66
  • 5 POSTS
do you have or know where i can get a diagram of the timing chain for this automobile and thanks alot for the help of the head bolts torque and order it was a big help
Nov 1, 2008 at 5:51 AM
