1999 Mitsubishi Galant Car shuts off after recent battery p
GETTINMYHANDSDIRTY
  • 1999 MITSUBISHI GALANT
  • 6 CYL
  • 45,000 MILES
My 99 Mitusbishi Galant ES, which my duaghter drives, had extreme battery corrosion on the battery terminals. I cleaned it and replaced the negative terminal, the wire had to be cut away, and I loosened the ground on the fender, then reinstalled the bolt, when finished. Daughter's cousin said the problem was the starter. So we replaced the starter, the car starts fine, but now after about 15 minutes of drivng, when she is at a stop sign, it dies. WHat could it be? Did I disrupt something? Further donation will occur with an positive explaination.
Wednesday, May 26th, 2010 AT 4:14 PM
CARADIODOC
  • 33,908 POSTS
Hi gettinmyhandsdirty. Welcome to the forum. If this is a new problem that just started after the battery was disconnected, the Engine Computer most likely just needs to relearn "minimum throttle". I can't say for sure with your car, but for Chrysler products, that takes place while driving the car. The conditions for this to occur include driving at highway speed with the engine warmed up, then coasting for at least seven seconds without touching the brake or gas pedals. At that point, the computer memorizes the voltage from the throttle position sensor. The next time it sees that same value, it will know it must be in charge of idle speed. Before that value is learned idle speed will be too low, and stalling at stop signs is the most common symptom.
Caradiodoc
Wednesday, May 26th, 2010 AT 5:43 PM
