1999 Mitsubishi Galant CAMSHAFT SENSOR MALFUNCTION
120,035 MILES • 4 CYL • FWD • AUTOMATIC
WILLIAMS28K
I know where the senosor is and have put a new sensor in but i have still have the fault code telling me that the camshaft sensor circuit is malfunctioning. How do I fix this problem. Is this a circuit issue that i can solve or is this a PCM problem this seem tobe a fault that is kind of common in 1999.
May 26, 2008 at 5:18 AM
  • 31,937 POSTS
Hi there,
With the new sensor fitted, have the code cleared. If it re sets, check the sensor plug on the loom for a loose or damaged pin connector first.
mark (mhpautos)
May 26, 2008 at 10:36 AM
