1999 Mitsubishi Galant Broken Turn Signal Arm
1999 MITSUBISHI GALANT
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
VICKROY
My turn signal arm has broken off at the point of attachment. It appears that I need to remove the cover over the steering column in order to attempt a repair. Is this feasible or should I not attempt
Jan 30, 2009 at 11:18 AM
  • 31,937 POSTS
Hi there,
I would get a mechanic to do this especially if you have an air bag, even if not air bag equipped the steering wheel will have to come off and often a special puller is required to do this.
mark (mhpautos)
Jan 30, 2009 at 12:13 PM
