1999 Mitsubishi Galant
1999 MITSUBISHI GALANT
TASHAKIAHG
Transmission problem
my car drives fine in reverse but doesnt acclerate at all or sometimes goes 10mph... what could be the promblem
Oct 2, 2010 at 3:18 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Oct 3, 2010 at 12:49 AM
