1999 floor is very wet on driver's side
145,000 MILES • 4 CYL • FWD • AUTOMATIC
RICO333
A couple weeks ago, I discovered that the floor under the driver's side floor mat was sopping wet. I can't figure out where the water's coming from. Have you seen this before? /any suggestions?
Aug 17, 2008 at 3:10 PM
  • 31,937 POSTS
Hi there,
Check that the A/c drain tube is not blocked and have the cooling system pressure tested just to be sure you have not got a leak in the heater core.Start here.
mark (mhpautos)
Aug 17, 2008 at 3:29 PM
