1999 floor is very wet on driver's side
RICO333
  • 1999 MITSUBISHI GALANT
  • 4 CYL
  • FWD
  • 145,000 MILES
A couple weeks ago, I discovered that the floor under the driver's side floor mat was sopping wet. I can't figure out where the water's coming from. Have you seen this before? /Any suggestions?
Sunday, August 17th, 2008 AT 10:10 PM
  • 31,937 POSTS
Hi there,
Check that the A/c drain tube is not blocked and have the cooling system pressure tested just to be sure you have not got a leak in the heater core. Start here.
Mark (mhpautos)
Sunday, August 17th, 2008 AT 10:29 PM
