1998 Mitsubishi Galant p0170 code
16,800 MILES • 4 CYL • FWD • AUTOMATIC
BADHAB31
I had a P0170 code. I checked for vacuum leaks, replace gas cap and added B-12 to the tank. I then erased codes and drove about 67 miles. Check engine light came back on. Now code is P0125. So I replaced the thermostat, erased codes and drove. Light came back on, P0170 again. I'm going to replace the fuel filter tomorrow thinking it may be fuel pressure problem. If that don't do it, what would you suggest next? and then? and so onl
Thank you in advance for you reply.
Dec 15, 2009 at 10:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check air flow sensor, fuel injectors, engine coolant temperature sensor, intake air temp. sensor, barometric or MAP sensor, heated oxygen sensor(s) and related connectors & harnesses to these components. Any or all of these could cause this fault code to appear. Also check fuel pressure, intake air leaks, and check for a cracked manifold.
Dec 15, 2009 at 1:17 PM
