1998 Mitsubishi Galant O2 sensor problems
1998 MITSUBISHI GALANT
150,575 MILES • 4 CYL • 2WD • AUTOMATIC
BDIEDRICH97
The check engine light was on and a scan revealed that there was an [O2 sensor heater circuit malfunction (Bank 1, Sensor !,)] which is the upstream sensor as I have been informed. That sensor has been replaced twice. I have also reset by disconecting the batery and cleared the the code with a state inspection computer. Other maintenance performed in an attempt to correct the problem includes cleaning the spark plugs and putting fuel system cleaner into gas tank. Yet the check engine light continues to come back on.
Jul 19, 2010 at 2:44 AM
KHLOW2008
  • 41,814 POSTS
Hi bdiedrich97,
Let me know the exact trouble code and I will get the diagnostic procedures for you.
Jul 19, 2010 at 4:48 AM
BDIEDRICH97
[quote:2fbea505e5="KHLow2008"]Hi bdiedrich97,
Let me know the exact trouble code and I will get the diagnostic procedures for you.[/quote:2fbea505e5]
the code is P0135
Jul 19, 2010 at 5:42 AM
KHLOW2008
  • 41,814 POSTS
DTC P0135: FRONT HEATED OXYGEN SENSOR (HO2S) HEATER CIRCUIT MALFUNCTION
1.Disconnect front Heated Oxygen Sensor (HO2S) connector. Connect Test Harness (MD998464 ) to front HO2S. Check continuity between ground and test harness terminals No. 1 (Red clip) and No. 3 (Blue clip) on Eclipse and Galant (California), or terminals No. 2 (Red clip) and No. 4 (Blue clip) on Galant (Federal). If continuity exists, go to next step. If continuity does not exist, replace front HO2S.
2.Start and warm engine until engine coolant temperature is 176°F (80°C) or more. Connect jumper wires between battery voltage and test harness terminal No. 1 (Red clip) and between ground and terminal No. 3 (Blue clip). Connect DVOM between test harness terminals No. 2 (Black clip) and No. 4 (White clip) on Eclipse and Galant (California), or terminals No. 1 (Black clip) and No. 3 (White clip) on Galant (Federal). Check front HO2S output voltage while repeatedly racing engine. If voltage is 0.6-1.0 volt, go to next step. If voltage is not as
specified, replace front HO2S.
3.Disconnect test harness. Turn ignition on. Check voltage between rear HO2S connector terminal No. 1 on Eclipse 2.0L and Galant (California), or No. 2 on Eclipse 2.4L and Galant (Federal). If battery voltage exists, go to next step. If battery voltage does not exist, check PCM connector and wiring harness between front HO2S connector and PCM.
4.Disconnect PCM connector. Turn ignition on. Check voltage between ground and PCM connector terminal No. 60 on Eclipse, or No. 90 on Galant. If battery voltage does not exist, check connectors and wiring harness between front HO2S connector and PCM. If battery voltage exists, check PCM connector. If PCM connector is okay, replace PCM.
© 2008 Mitchell Repair Information Co., LLC.
Jul 19, 2010 at 6:02 AM
