engine high idle speed?
89,000 MILES • 4 CYL • FWD • MANUAL
DAVEMC123
Hi this is my mothers car, since she bought it she has a problem with the idle speed. i have changed the clutch, air flow sensor, throttle body, idle control valve, air recirculation valve, the only thing i haven't changed is the ecu!!! is there anything else i could be missing?????
May 12, 2010 at 6:17 AM
CHIRAG_NINE
Hi, I got 2002 galant LS 2.4L!
I also changed the air flow sensor and air control valve. doesnt seem to idle to car. RPM is @1400 while parked. and during drive its @700 and when i start A/C RPM drops as well. Service engine light is also on. dont know what to replace!
I was wondering if you got it fixed.
Aug 2, 2010 at 4:13 AM
  • 55,561 POSTS
It sounds like the throttle cable needs to be adjusted, here is a guide to help and instructions below for the adjustment.
https://www.2carpros.com/articles/engine-idles-too-high
Check out the images (Below). Please let us know how it goes
Sep 25, 2023 at 3:09 AM
