1997 Mitsubishi Galant break lights
1997 MITSUBISHI GALANT
100,000 MILES • 4 CYL • FWD • AUTOMATIC
KDOT27
hello, i am having problems with my break lights,they don't work,i have change the fuse and the bulbs,but it still didn't solve the problem, can you help me please?
Mar 16, 2008 at 8:40 AM
MASTERTECHTIM
  • 4,750 POSTS
the most lkely cause is a faulty brake light switch. its located above the brake pedal and are fairly easy to replace. to test you need to check the wires at the plug, one wire will be positive all the time and the other wire will be positive when the brake pedal is pressed. if you cant get a wire to light the test light when pressing the pedal then you know for sure. hope this helps
Mar 16, 2008 at 8:55 AM
