1997 Mitsubishi Galant ball joint issue
RX7
Suspension problem
1997 Mitsubishi Galant 4 cyl Two Wheel Drive Automatic
it appears to have two lower ball joints. one comes form the lower control arm but there is a second ball joint to the left of it. this is on the front passenger side. the second ball joint is gone and the car is wobbling really bad at high and low speeds. the ball joint seems to be connected to a bracket that goes to the from nobody knows what it is or what it is called and i need to replace it any info on it would be great.
Nov 21, 2008 at 5:03 AM
  • 55,500 POSTS
I beleive it is called a strut rod.
Nov 22, 2008 at 1:52 AM
