1996 Mitsubishi Galant
1996 MITSUBISHI GALANT
143,000 MILES • 4 CYL • FWD • AUTOMATIC
STEFFYLEE622
I have a 96 Galant. I recently got my car back from having the transmission replaced. The car seems to be running fine but I am hearing a low humming noise now. It happens when the air is on and it continues to make the noise after I turn the car off. I was told it might be the air compressor but I am not sure.
Jul 21, 2008 at 4:29 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi SteffyLee622,
When the engine is turned off, the compressor stops so the noise could not be from it.
I would suspect the radiator or condenser fans to be the culprit. Check if any foreign materials are in the way of the fan blades.
Jul 23, 2008 at 5:51 AM
