1995 Mitsubishi Galant runs rough at idel
104,000 MILES • 4 CYL • 2WD • AUTOMATIC
STLLHOT34
I WAS DRIVING AND ALL OF A SUDDEN I STOPPED AT A LIGHT . WHEN I DID THE CAR STARTED TO RUN ROUGH . I DID A TUNE UP . PLUGS , WIRES , CAP , FUEL FILTER , THE WORKS . I STILL RAN THE SAME WAY SO I STARTED REPLACING PARTS . I STARTED WITH THE IDLE SENSOR , MAP SENSOR , FUEL INJECTORS AND RAIL . STILL NOTHING . CHECKED THE SPARK , TIMING , FUEL PRESSURE ALL GOOD . I DON'T NO WHERE TO TURN NOW . I HOPE YOU CAN HELP . THANK YOU FOR YOUR TIME
Sep 16, 2008 at 2:54 PM
  • 31,937 POSTS
Hi there,
do a scan and check the engine compressions first.
Mark (mhpautos)
Sep 16, 2008 at 3:04 PM
