1995 Mitsubishi Galant overdrive
KINGOFPOWER
  • 1995 MITSUBISHI GALANT
Transmission problem
1995 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic 96k miles
95 galant s when I drive and the overdrive is off it drive fine. When I turn overdrive on it feel like it in neutral
Monday, November 30th, 2009 AT 9:14 PM
MITSU BLA SHI
Around 45 mph is overdrive speed for engagement. The lower your driving speed, the more sluggish it will be. If all gears 1-2-3 have more power, the possible problem can be the electronic overdrive lock-up converter. A.K.A your torgue converter may be slipping. Try changing the trans fluid and filter with addition to a trans conditioner. It may help.
Thursday, January 7th, 2010 AT 10:50 PM
