When i try to crank, i would have to repeatedly turn key and finally it would crank?
Jan 16, 2009 at 1:03 PM
BLUELIGHTNIN6
✓Experienced Mechanic
Hello
Suspect faulty ignition switch. Try spraying WD-40 or equivalent into ignition switch and work it in with key. If this temporarily solves the issue then replacement of switch will be required.
