1995 Mitsubishi Galant ignition
1995 MITSUBISHI GALANT
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CLACKJR88
When i try to crank, i would have to repeatedly turn key and finally it would crank?
Jan 16, 2009 at 1:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Suspect faulty ignition switch. Try spraying WD-40 or equivalent into ignition switch and work it in with key. If this temporarily solves the issue then replacement of switch will be required.
Thanks for using 2CarPros.com
Jan 16, 2009 at 2:22 PM
