1994 Mitsubishi Galant starter reley
209,000 MILES • 4 CYL • FWD • AUTOMATIC
MISSY8806
I HAVE A 94 MITSUBISHI GALANT AND I AM HAVING TROUBLE STARTING IT I HAVE PUT A NEW STARTER IN IT AND A NEW EGNITION SWITCH AND IT WORKED FINE THEN IT STARTED NOT WANTING TO START AGAIN SO CAN ANYONE HELP
May 3, 2009 at 6:37 AM
ATKAPARKING
  • 64 POSTS
You'll need to load test your battery, to make sure it doesn't have dead cells and is fully charged. Yes, I know it's new, but batteries have a high rate of failure. Check and clean all connections, including the ground from the battery to the engine/frame. Then you'll need to verify if you have signal voltage to your starter. Also put a remote starter or hook up a wire with alligator clip directly from positive battery post and where the starter signal wire goes---this will verify that your starter is good. If you have replaced the starter yourself, good job--you should be able to handle some more advanced troubleshooting methods to determine your problem.
May 4, 2009 at 12:46 PM
