1992 Mitsubishi Galant Where does this wire go?
165,433 MILES • 4 CYL • 2WD • AUTOMATIC
ROBDOB
I installed a new alternator on my girlfriend's 1992 Mitsubishi Galant. The wire "loom" or "harness" that goes to the alternator has the following wires:
1) main wire that goes to the stud coming out of the back of the alternator;
2) a plug with two terminals that plugs into the back of the alternator;
3) a single wire that goes into the oiil filter mount area;
4) a single wire, in a sleeve, with a single "barrel" type plug on trhe end that isn't connected to anything.
It's that fourth wire that isn't connected to anything that I'd like to know where to connect - it looks like a single, round, push on type plug.
Can anyone help? Reply to: robdob4@yahoo.com
Thanks
Rob
Jun 21, 2008 at 11:47 AM
KHLOW2008
  • 41,812 POSTS
Hi robdob,
That should be connected to the power steering pump. If you cannot find any switch on the pump, it is not used.
Jun 21, 2008 at 11:14 PM
