1992 Mitsubishi Galant Sunroof
135,000 MILES • 4 CYL • AWD • MANUAL
PALBA
The sunroof is stuck open. Is there a way to manually close it until I can fix it?
Jul 23, 2009 at 12:01 PM
KHLOW2008
  • 41,812 POSTS
Hi palba,
If the motor is not bad, you can try applying voltage to it to close the sunroof.
Remove the sunroof switch and dome light assy.
Remove the headlining and you can gain access to the motor.
Disconnect the motor and apply voltage to it. Reversing the polaity would open and close the sunroof. If motor is bad, remove motor and you can manually pull the sunroof close.
Jul 26, 2009 at 6:15 AM
