1991 Mitsubishi Galant Alternator problem
135,000 MILES • 4 CYL • FWD • AUTOMATIC
AUTOMOM4
My son just bought a used 1991 Mitsubishi Galant GS/GSR. The seller said it needed a new alternator. He had the old one checked and it was bad--so he replaced it. When he disconnects the battery cable, the car dies--had the new alternator tested (just in case) and it is good. Tried different battery and same thing. Whay else could be wrong?
Sep 19, 2009 at 8:10 AM
DOCFIXIT
  • 18,828 POSTS
Does alt charge battery stayup?
Sep 19, 2009 at 8:31 AM
AUTOMOM4
[quote:485228bd86="Docfixit"]Does alt charge battery stayup?[/quote:485228bd86]
no -- the battery runs down
Sep 20, 2009 at 10:33 AM
DOCFIXIT
  • 18,828 POSTS
May have a battery drain will need a Volt Ohm Meter.
Do you have one?
Sep 22, 2009 at 3:19 AM
AUTOMOM4
[quote:8c08c33cd8="Docfixit"]May have a battery drain will need a Volt Ohm Meter.
Do you have one?[/quote:8c08c33cd8]
no, but we've tried other batteries with the same result
Sep 22, 2009 at 3:55 AM
