1995 Mitsubishi FTO rev counter
1995 MITSUBISHI FTO
102,432 MILES • V12 • 2WD • MANUAL
LEANNEGREG
hi my rev counter will not go over 6.5 k although the dials go right up to 9 it feels like there is some sort of limiter on there or it is red lining at 6.5 but surely that cant be right? any help be apptreciated
Oct 11, 2009 at 10:48 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 11, 2009 at 11:18 PM
