2005 Mitsubishi Endeavor Spark Plug Coils
2005 MITSUBISHI ENDEAVOR
70,000 MILES • 6 CYL • AWD • AUTOMATIC
DARRYLARD
Can the engine run on 5 cylinders if one of the coils is bad? What kind of damage could this do and how long might it run before serious damage occurs?
Aug 4, 2010 at 1:53 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Yes if one of your coil's is bad it would cause that cylinder not to run.As far as damage from that it's putting a strain on the engine from that cylinder not firing and throwing the engine off balance.Also if that cylinder isn't working your putting extra fuel in the catalytic convertor and will damage it and there really expensive.So i would get it fixed right away.I can't give a time frame when damage happens i can only tell you to get it fixed right away.
Aug 4, 2010 at 4:32 AM
