I recently purchased a 1998 eclipse and was told it had no leaks, after a test drive everything was dry and clean. Shortly after 3-4 days I noticed a drip coming from under the car and oil around the head gasket. So I had the head gasket replaced and the oil pan gasket (it was over torqued) was replaced at the same time, now I was told there was also a possible rear main seal leak. I was also told it could be the oil pressure regulator. I don't want to keep paying for fixes and get no where. Any ideas?
SPONSORED LINKS
Saturday, June 7th, 2008 AT 12:13 PM
