2004 Mitsubishi Eclipse Engine
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
DMAN81
Hello, just a quick question. I have a 4 cylinder and its pretty slow, now i know that its gonna be slow no matter what, but is there anything i can check or clean that might be effecting the speed/acceleration! Also are there any not to expensive ways to increase speed/acceleration. Like anything i can buy, im not looking to win a race just to have a little more go when i hit the pedal. (ps is it possible to make the wheels smoke with have a 4 cylinder?)
Thank you for all your help
Feb 16, 2010 at 12:36 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 16, 2010 at 10:26 PM
