2004 Mitsubishi Eclipse Broken Spark plug
84,000 MILES • 4 CYL • 2WD • MANUAL
RMARAPAO
how do i take out a broken spark plug inside the engine?
Apr 23, 2009 at 7:37 AM
  • 31,937 POSTS
Hi there,
if the plug id broken and only the threaded section and core remain, the head will have to be removed because if the ceramic insulator enters the engine you will do considerable damage when the engine is run and the likely hood of you being able to retrieve it is remote at best.
Mark (mhpautos)
Apr 23, 2009 at 5:02 PM
