2003 Mitsubishi Eclipse wont start
146,879 MILES • 4 CYL • FWD • AUTOMATIC
MICHAEL1234
cranks over no start replaced following parts one coil pack cam senor plug wires used test ligth found juice at cam &cranK SENORS COIL PACK ALSO BUT NO JUICE COMING OUT WHEN CRANKING THIS STARTED WHEN CAR STARTED UP AND I PUT INTO DRIVE IT SHUT DOWN AND CANNOT START IT
Jan 21, 2008 at 12:04 AM
2CARPRO JACK
  • 11,533 POSTS
So your saying it has no spark? Get a "noid" light and see if it has injector pulse at the plugs.Is the cam turning? be sure the timing belt didnt break. Might also be the crank sensor
Jan 21, 2008 at 11:30 PM
