2003 Mitsubishi Eclipse Throttle position sensor
102,000 MILES • 4 CYL • 2WD • MANUAL
DICK JORDAN
From reading on this site of similar problems, it appears I have have a problem with the throttle position sensor. The car hesitates when running at low RPM's, or when taking off from a stop. The "service engine soon" light has been on for a couple of weeks, and I'd like some info on how to locate and replace the sensor.
Jan 13, 2009 at 2:06 AM
DOCFIXIT
  • 18,828 POSTS
Need to know what code is set go to an AutoZone or simliar and have codes read then post will advise.
Jan 13, 2009 at 2:13 AM
DICK JORDAN
[quote:0252f54556="Docfixit"]Need to know what code is set go to an AutoZone or simliar and have codes read then post will advise.[/quote:0252f54556]
I assume autozone runs a diagnostic? How much do they charge for that?
Jan 13, 2009 at 3:19 AM
DOCFIXIT
  • 18,828 POSTS
Free
Jan 13, 2009 at 3:47 AM
DICK JORDAN
[quote:e91b1fd9b0="Docfixit"]Free[/quote:e91b1fd9b0]
Thank you for the info!
Jan 13, 2009 at 4:52 AM
