2003 Mitsubishi Eclipse slave clutch cylinder
140,000 MILES • 4 CYL • FWD • MANUAL
BILL DAVIDSON
I need to replace my slave clutch cylinder but have no idea how. I have the placement but I don't know where to begin.
Jan 16, 2008 at 10:14 AM
  • 75,988 POSTS
What's wrong with the slave/servo that you are replacing it. The slave is nearby the transmission bell housing. it has a push rod on it, that pushes the clutck fork to disengage the clutch disc thru the clutch cover/presure plate in order to shift.
Jan 16, 2008 at 2:00 PM
