2003 Mitsubishi Eclipse Removal of trunk lid struts
120,000 MILES • 4 CYL • FWD • AUTOMATIC
BREYMONT
sub model: Spyder GS with spoiler. Trying to remove and replace trunk lifts (struts). Can't find the right tool to unscrew the bolts. Appears to be a 3/16 allen head; but that just slips when trying to turn it.
Maybe it is a hex head? If so what is the size I need to remove the bolt?
Nov 8, 2009 at 4:13 AM
SERVICE WRITER
  • 9,123 POSTS
IF it looks like a hex, it's probably a metric size. Best off getting a set that has multiple sizes. You'll come across a time that you'll be glad you have a set. I can't see it being more than 10 bucks for a standard set of them.
Nov 8, 2009 at 10:48 AM
BREYMONT
Is there a difference between allen head wrench and a hex head one? They both to be 6 points and they screw heads look almost identical.
No access to repair instructions for this vehicle that will tell you exactly what to use?
Nov 16, 2009 at 8:49 AM
SERVICE WRITER
  • 9,123 POSTS
I would need to have the car to be able to tell you what the right size is, but the 6-point you describe is a torx bit:
http://images.google.com/images?hl=en&source=hp&q=torx+bit&btnG=Search+Images&gbv=2&aq=f&oq=&aqi=
I still recommend getting a set as they are common, but a stop into the parts store will get you the specific size.
Nov 16, 2009 at 9:43 PM
