2003 Mitsubishi Eclipse power windows
2003 MITSUBISHI ECLIPSE
SMILLEEGUY
Interior problem
2003 Mitsubishi Eclipse 6 cyl Two Wheel Drive Automatic
how do u remove the brackets that holds the regulator or motor from the door..is it as easy as removing the bolts? does the window have to be down or up for it to be removed? please advise step by step and if can provide pictures please. thank you..SMILLEEGUY
Jul 2, 2008 at 4:44 PM
KHLOW2008
  • 41,814 POSTS
Hi smilleeguy,
The glass have to be released from the regulator before it can be taken out, look out for the point where the glass mounting bolts are accessible.
After removing glass, you can proceed with removal of attaching bolts and motor.
Jul 5, 2008 at 2:51 AM
