Computer problem
2003 Mitsubishi Eclipse 6 cyl Manual
I HAVE 2003 ECLIPSE 3.0 MANUAL TRANS. THE CAR SAT 3 WEEKS WITH THE REAR END JACKED UP AND THE CAR FACING UP HILL. IT RAINED HEAVILY SEVERAL TIMES AND IT SEEMS LIKE THE SUNROOF? LEAKED BUT APPARENTLY THERE WAS A FAIRLY LARGE AMOUNT OF WATER ON THE PASSENGER FLOOR. NOW THE CAR WILL CRANK OVER BUT NOT START. IT DID START BUT ONLY RAN FOR A FEW SECONDS THEN MADE A WHIRRING NOISE AND SHUT OFF. IT CRANKS LIKE IT HAS NO COMPRESSION, I CHECKED AND THE FRONT BANK WAS LOW ACROSS THE BOARD- 60-80 PSI. I CHECKED THE TIMING BELT AND IT IS IN TIME AND OK. THEN MAJICLY THE CAR STARTED AFTER REASSEMBLY BUT HAD A SES LIGHT ON, CODES FOR CAM AND CRANK SENSORS. THE CODES RESET EVERY TIME THE CAR IS CRANKED AND WHEN IT DID RUN THEY BOTH RESET EVRY TIME. SO, MY QUESTION IS WHAT COULD MAKE THE CAR RUN THEN MAKE A WHIRRING NOISE AND LOSE COMPRESSION? THE VOLTAGES AT THE SENSORS ARE CORRECT AND THE OHM READING IS .6 OHMS. I CHECKED THE ECM , DOES NOT FEEL DAMP AND THE CONNECTORS ARE CLEAN AND DRY. WHAT AM I MISSING?
Aug 25, 2009 at 9:30 AM
